vcJointDriver
A driver in a vcMotionController.
Module: vcRobotics2
Referenced by: vcMotionController.Drivers, vcMotionController.ExternalDrivers, vcMotionController.createDriver(), vcMotionController.setToolCenterPoint(), ... (see more)
vcMotionController.testExternalDriverValueLimits()
vcMotionController.testInternalDriverValueLimits()
vcSingleDofLinkJoint.Driver
| Acceleration | vcRealExpressionProperty | R | Gets an expression property that determines the "nominal" acceleration of this driver. Used e.g. in motion planning. |
| ActiveController | vcMotionController | R | Gets the controller that has control of the driver. Can be different from OwnerController if the driver is exported to another controller. |
| Deceleration | vcRealExpressionProperty | R | Gets an expression property that determines the "nominal" deceleration of this driver. Used e.g. in motion planning. |
| ExternalIndex | Integer | RW | Gets or sets the external index for the driver.See moreIndex must be equal or grater than zero. Assignment can raise error. Exceptions: ValueError: When index is reserved by another driver or index can't be assigned e.g. when the driver is not exported. |
| InitialValue | Real | RW | Gets or sets the initial value of the driver. |
| InternalIndex | Integer OR None | RW | Gets or sets the internal index for the driver.See moreIndex must be equal or grater than zero. Assignment can raise error. Exceptions: IndexError: When index is out of bounds. ValueError: When index editing is disabled e.g. during simulation. |
| Jerk | vcRealExpressionProperty | R | Gets an expression property that determines the "nominal" jerk of this driver. Used e.g. in motion planning. |
| MaxLimit | vcRealExpressionProperty | R | Gets an expression property that determines the maximum value for the driver.See moreThe only available variables are the other JointDrivers in the same controller, and INF can be used for infinitely rotating drivers. |
| MaxVelocity | vcRealExpressionProperty | R | Gets an expression property that determines the maximum velocity of this driver. Used e.g. in motion planning. |
| MinLimit | vcRealExpressionProperty | R | Gets an expression property that determines the minimum value for the driver.See moreThe only available variables are the other JointDrivers in the same controller, and -INF can be used for infinitely rotating drivers. |
| Name | String | RW | Gets or sets the driver's name. |
| OwnerController | vcMotionController | R | Gets the controller that owns the driver i.e. the original controller. |
| Properties | vcPropertyContainer | R | Gets the property container. |
| TurnCenterPoint | Real | RW | Gets or sets the center point used for turn calculations.See moreThis can be used to offset the turn ranges/span. The span is applied symmetrically around this point. The default is zero. |
| TurnInclusiveLimit | vcJointDriverInclusiveLimit | RW | Gets or sets the center point used for turn calculations.See moreThis can be used to offset the turn ranges/span. The span is applied symmetrically around this point. The default is zero. |
| TurnSpan | Real | RW | Gets or sets the span of a turn, i.e., the range of values that belong to a turnSee moreFor turn 0, the range is then from(TurnCenterPoint - TurnSpan / 2) to(TurnCenterPoint + TurnSpan / 2). |
| Value | Real | RW | Gets or sets the value of the driver. |
| delete | None | None | Removes the driver from its owning controller and deletes the driver.See moreReturns: None Exceptions: InvalidOperationError: When the driver is currently exported via connected interface. |
